diver57
Jan 08, 2016Explorer
new dually
Hi i am thinking about ordering a new Denali dually with either a bigfoot camper or northern -lite Question is it better to get a I think a 7.30 or a 4.10 gears for the truck rear end, what is t...
deltabravo wrote:Kayteg1 wrote:
The only issue is that with low differential and 2WD your low gear might be too high, but with 4WD you will have transfer case changing gearing.
Transfer case doesn't change gearing in normal operation. 4LO does change it, but you sure can't be running around in that towing something on the highway.
