Steverino54's avatar
Steverino54
New EC1165 Slide Misalignment?
Hi All,
After 2 yrs of reading/researching, finally ordered a 2018 EC1165 to go on a 2017 F550 with Douglass camper body. Arrived at the TC dealer late yesterday with just enough time to briefly see the camper prior to getting trained and accept ownership later today...
Am a bit concerned that all 3 slides appear to be off alignment when viewed with the slide closed. Standing back and visually comparing the top and bottom corners...the slides appear to be rotated slightly counter-clockwise in the opening. In other words, when you line up the upper LHS corner with the main body seal molding (metal), the bottom LHS corner is off 1/2" to the right - and when you line up the bottom RHS corner, the upper RHS corner is shifted 1/2" over to the left. Additionally, the bottom surface does not appear to be as tightly sealed against the main body as the top - there is a 1/8-1/2" gap metal to metal at the bottom.
All of the other TC's (AF, Host, EC) on the lot have their slides open with no batteries installed so I cannot compare with mine. The very good salesman could see what I was seeing and took some photos to email the factory for comment.
All I want is for the slides to operate and seal properly for many service-cycles during the next 10 yrs. Before I accept ownership today...
Am I being unreasonably perfectionistic?
Is the "off 1/2" normal slide construction?
  • Steverino54 wrote:
    Thanks Greg and Pete! I have previously read about slide syncing and wonder if that is the problem vs. poor construction...how will I know the difference? Maybe if we go through the re-ync process and the slides do not square up with the opening?
    Here is a short video from lippert on how to re-synch the slide. This looks like a simple process, but I guess there could be more. I have also heard that with 2 motors (as apposed to one using a rack) even little stuff like the length of wire to each motor can make a difference in their timing.
    Re-time a schwintek slide
  • Thanks Greg and Pete! I have previously read about slide syncing and wonder if that is the problem vs. poor construction...how will I know the difference? Maybe if we go through the re-ync process and the slides do not square up with the opening?
  • As an observation: We are at the Balloon Festival in Albequerque with 1400 other RV’s in our lot. I only see Schwintek used on smaller and lighter slides. All the rest use some type of under-slide drive system.
    Have the dealer realign the slide to get this corrected. If the dealer cannot get it straight, do not accept the unit with promise of it getting fixed later.
  • Not being unreasonable. Dealer should be able to hook up the other units with a battery for you to compare. The slide has 2 motors and if they aren't synched exactly the slide won't be square to the main body. Youtube has more info on lippert schwintek slide alignment and troubleshooting.
