LVJJJ wrote:
opnspaces, I see you have a 3/4 ton 96 Burb with a 350. How does it tow? seems like a lot of weight for a 350. I have a '94 Burb with 350 K-1500, 3.73 1/2 ton, the engine runs good but is low compression and is really weak. I've done several exterior upgrades so it tows halfway decent, pulling a TrailCruiser 26' just okay. Have you had to upgrade your engine much?
(dual exhaust, Fastchip computer upgrade chip, two cold air intakes, adjustable timing control, 15* advance)
Mine is stock, and up until the last few months it has towed great. Lately I notice it is not as fast up the hills as it used to be but it also just turned 190,000. I do have the 4.10 rear end which I'm sure helps and I'm also not shy about dropping it to second, putting my foot on the floor and holding it there until I get to the top. The worst thing is encountering a commuter car half way up the grade that causes me to drop out of the power band. Then it's just a slow crawl to get back up to speed. Since I still have kids I'll probably look for a 3/4 ton with a 454 when this one dies.
