wanderingaimlessly wrote:
Going back to the OP's comment.
He would not have enough range to go to son's house. When there, he would be stuck with trying to charge using a standard 15 amp outlet, which will take DAYS to charge for MOST of the return trip.
Or, just stop in at a public charger for 15 or 20 minutes and spend 8 or 10 bucks. It depends on ones schedule I suppose.
IF one is close by and available.
Yes that’s true. That depends on infrastructure. In our province DC fast chargers are pretty much ubiquitous and more everyday. But every region is different of course. Always best to analyze your personal situation.
And on top of this, normally people dont calculate the use of heat or AC into a vehicle trip, BUT with these electric vehicles, the use of either further reduces your useful range by 30-50%, so on a summer day, that 350 mile trip will now requires 2 stops to recharge due to the AC reducing the already limited range.
And since this thread was started as a "Tow vehicles" thread. lets further reduce the range again, to where that F-150 with a claimed 300 mile range will likely have only 90 to 120 miles available when pulling your trailer on a summer day.
Welcome to the 1930's.
I can’t speak for other vehicles but certainly our present EV uses no where near those suggested numbers. Typically AC draws around an additional KW plus or minus. Think of a small 5000 btu Home Depot air conditioner mounted in a small space like a car. It doesn’t take long to turn it into a meat locker. If you are stuck in traffic for 8 hours and wanting to keep cool an EV is a great place to be. You might use 10 percent of an 80 KWh battery. Really, running AC is not a big deal. The car figures it out and calculates your required charging stop and location accordingly.
Cold? It depends. If your EV has a heat pump it’s not too bad down to a certain point before resistance heat kicks in. If you have an older EV that only had resistance heat you can lose a third or more of your range. Either way, the car figures it out and calculates your charging stop and location accordingly.
Of course, as always, analyze your own needs and see if it’s right for you. For our needs and performance expectation gas vehicles have lots of disadvantages and no advantages so it’s an easy decision. But others with different needs and expectations may be better suited to gas vehicles.
Can’t speak to towing as we have no experience towing with an EV.
I’m not sure if the OP was planning on towing to his sons house, although I didn’t get that impression.
Cheers.
