CptSydor's avatar
CptSydor
New F150 - Brake Controller Install
Well I just pulled the pin on a new F150 tonight. Supercab 4x4 5.0L V8 with 3.55. 7800lbs tow, payload of ~1850 lbs. :)
First trip will be in a couple weeks. 4000 miles round trip to Colorado. Only pulling my small Dutchman t@da (2200 lbs dry). Will be upgrading next spring to a larger TT.
Truck has a tow package, but needs a brake controller. From everything I've been reading/watching even before the purchase, this should be a simple plug and play. Buy a controller, should have a factory adapter, find the connection under the dash, snap, crackle, pop, screw and I'm ready to go.
Just here to make sure I'm not under estimating anything.
  • APT wrote:
    Yes, I highly recommend the OEM integrated brake controller. Last time I checked for 2011 models it was comparable in cost to the Prodigy P3 at about $125. It will need to be enabled via a dealer service tool, though.
    Agreed, the OEM controller seems to outperform even the highest end aftermarket controllers. I'd definitely go for it if I didn't own a brake controller yet.
  • Yes, I highly recommend the OEM integrated brake controller. Last time I checked for 2011 models it was comparable in cost to the Prodigy P3 at about $125. It will need to be enabled via a dealer service tool, though.
  • Yep, get a Prodigy, adapter for the factory plug and you are good to go. I have done this a couple of times on Ford trucks.
  • If you install the Ford Factory controller you will need to have the dealership activate it for you via the OBD port and their computer. If you go with the aftermarket just attach it to the harness and plug it in. That's the way I went. Now I will be pulling it from the truck and installing it in the motorhome.
