- Skid_Row_JoeExplorerAlls you need in a 2WD PU, is posi-traction rear axle, Blizzaks, weight in the bed, and chains when necessary.
I've never had any trouble getting around in Wintertime with any of my posi-traction Corvettes. Including my C7.
. - 1320FastbackExplorerI dont need a 10spd transmission in my truck but its getting one, I dont need a solid axle Dana 60 up front but its getting one, I didnt need a 500cc 2 stroke engine in a modern 4 stroke motocross chassis but I did that too.
Life is full of choices, do what you want and forget what anyone else thinks. - blt2skiModeratorGrit dog, not promoting 2wd trucks. Just saying Washington law states..........4wd or not!
yes turning a knob, pulling a lever, doing nothing in an awd is nicer than than a rwd with or with out a locker/posi! yes, one will be chaining up a lot more with a rwd. A semi with a front driving axel and the rears driving, pulling a trailer thru snoqualmie with the over 10K chain up sign up, will/may not get over with out the WSP ticketing them generally speaking. I never tried it when pulling my RV in Wa, Or or Idaho! That sign was up, chains went on.
Now that I am typing, I went up Stevens one time in rwd with the chains required sign on all rigs. Did ot put into 4wd until I hit the parking lot. Even a rwd with a locker can get places and open rear will not with proper tires.......
Marty - Grit_dogTrailblazer^ you’re obviously promoting the 2wd trucks. That’s cool. I can challenge myself to plow through snow in a 2 wheeler, but 3x this year already I’d have had to chain up “by law” just driving back from meetings in E WA on I90 if I didn’t have a 4x4 company truck. (In that event I’d have taken my personal rig though). I like the “instant tire chains” by turning a knob on the dash!
- blt2skiModerator
burningman wrote:
Another big plus, in winter here in the NW on several highways you have to chain up if you were dumb enough to not buy a four wheel drive.
If you know the actual laws, You would know, that 4wd with no chains is only legal if you are not over 10K lbs licensed weight, and not pulling a trailer. So if you own a dually pickup that is 4wd. If the WSP has a sign up, all vehicles over 10K must use chains, techniquely, you need chains on the rear axel! Altho many wsp officers will let you by......if in a wreck, they may lighten you wallet for not having chains on your over 10K rig.
If the gvw of the truck and trailer are over 10K, or you are pulling a trailer of ANY size, you need chains on the rear of the tow rig, and a drag chain on the trailer, assuming it has brakes.
Not saying a 4wd towing an RV trailer with chains on the rear, drag on the trailer is easy, but legally, that is what one has to do! Been there done that in multiple states here in the western region. As that is how the laws state it!
marty - monkey44Nomad IINo one needs a 4x4, until he needs it once. Then he knows instantly why others buy only 4x4 trucks.
- burningmanExplorer IIAnother big plus, in winter here in the NW on several highways you have to chain up if you were dumb enough to not buy a four wheel drive.
K Charles wrote:
I am not a famers,ranchers, cops, or logger but I have needed to use my 4 wheel drive often and I don't live in canada. If I go where there is mud or sand or snow or wet grass I sometimes need it.
Ditto.
99.99999% of truck in the lots in Washington are 4x4. It's difficult to find a 2 wheel drive truck.- 1stgenfarmboyExplorer
Copperhead wrote:
Yeah, not so much of an issue on prairie flat land. Not so sure those that have to drive hilly gravel roads and such would concur that a few bags of sand and lower inflation will do the truck, especially in the spring when that ice and snow melts and turns those roads into a mud bog event.
I don't live in flat land, I live in the Shawnee National Forest, it's a long way from flat.
Plus I have to drive a little while to get to a hard road. - CopperheadExplorerYeah, not so much of an issue on prairie flat land. Not so sure those that have to drive hilly gravel roads and such would concur that a few bags of sand and lower inflation will do the truck, especially in the spring when that ice and snow melts and turns those roads into a mud bog event.
