mobeewan
Jan 24, 2015Explorer
I use queen size fitted sheets and single (twin size) flat for the bunks. I put a full size queen mattress on top of the short queen 4 inch foam mattress in the front bedroom so I already had queen fitted sheets.
I noticed the bunk mattresses were about queen length. I pulled out a bunk mattress and set it on edge on the floor. I wrapped a full size queen fitted sheet all the way around the mattress and hooked all 4 corners of the sheet on the same mattress edge. Then slid the mattress back in place fully wrapped in the fitted sheet on all 4 sides. Works best leaving the sheet corners next to the aisle with the last corners of the sheet hooked from the top like they would normally be.
Then I just use a twin top sheet tucked over and under the wall edge of the mattress and at which ever end will be the foot of the bed.
So all I have in the trailer is fitted queen, flat queen and flat twin sheets. No need for special and expensive sheets for the bunks.
44,067 PostsLatest Activity: Jun 03, 2026
