Gdetrailer
May 30, 2013Explorer III
Not sure as to why you would use Simple green since it is a degreaser.
I wouldn't suggest using it unless you are degreasing a engine.
Dish detergent is all I use and lots of water wash small areas at a time basically soap an area then rinse quickly. Do this at cooler times of the day and when not in direct sun. Otherwise you risk having dried detergent.
Water quality can also affect the outcome, if using well water or poorly treated city water you may also get mineral deposits (AKA HARD or non softened water) which show up as a white haze. This can be corrected by washing/rinsing with softened water.
44,029 PostsLatest Activity: Jan 28, 2025
