OutdoorEscape's avatar
Jun 26, 2025
New Here!!
Hi y’all, I just purchased my very first camper, a Keystone Coleman 23B I’ve gone camping many times before but never in a camper, any tips or tricks would be appreciated! I’m most nervous about the black and grey water and making sure I do that right. My first trip will be over the 4th so I’m getting everything I think I need together. Are there any “must haves”  that someone new wouldn’t think of? Thank you in advance for any information or help!
  • “And gray is easy to sneak some out of the tank if you’re parked and get er a bit too full. ”
    Don’t be that guy
  • Enough blocks, boards or Lego’s to level it up.
    A way to change a flat trailer tire.
    sewer hose.
    Proper extension cord if it will be hooked up.
    Black and gray is easy. Gray will be full first in normal use. Keep an eye on sink/shower usage but worst case gray water generally backs up into the shower pan first when slightly overfull. And gray is easy to sneak some out of the tank if you’re parked and get er a bit too full.
    If you have a 2 way or 3 way fridge, LP setting is your friend if not plugged in. Fridge on DC will kill a decent pair of batteries in relatively short order especially in the summer.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      that will get you a huge fine and probably banned from the parks system you do it in up here.  probably the worst advice you can give a newbie
