AnEv942
Apr 23, 2018Nomad
Thanks wnjj, Yes my physical install is documented on our home page. I rarely point to it other than the sig
link as it outlines as much that didn't work as did. Id think difficult to glean any info as far as decision making.
For the WiFi I used the Ubiquiti NanoStation M2 system that msiminoff outlined in aidwillis thread on his WiFi setup.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29582693.cfm
Mounted outside antenna, it's directional, on the Winegard- to point.
On the cell I ended up going with the (Wilson Electronics) Weboost RG-X RV. I havnt added any thread info.
Its pretty expensive and its difficult to get enough separation between inside & outside antenna (on a truck camper).
So far I'm impressed but haven't any on the road use yet.
I ended up putting outside antenna on ~4' mast but didn't want extra setup of assembling /raising so its on a ratchet mount.
Also wanted it at rear of camper for access.
So that's where aux. ladder came in. I can reach either semi permanent mounted antenna from perimeter of camper.
Weboost makes the same system but with smaller antennas that can be mounted closer to each other.
Wanted to maximize signal- and limited research kept leading me back to the Weboost. There likely is equal
systems that may cost less- I just wasn't having any luck finding a lot of positive info for cell use.
