fallsrider's avatar
fallsrider
New Maxxis tires
I'm sitting at Discount Tire waiting to have new Maxxis M8008 tires put on my '95 Sunnybrook 26DB. I put a new set on 9 years ago when we bought the trailer and they have been flawless for us. New tires aren't cheap! But I think I've pushed their age long enough.
My Dad and I are pulling it down to the Outer Banks of NC in October for some surf fishing. It's 5 hours each way. Didn't want to take any more chances.
  • fallsrider wrote:
    RCMAN46 wrote:
    I had a set of Maxxis M8008 on my 5th wheel and had tread separations in 5 years with very little wear on the tires.
    I also had a set on a small single axle utility trailer that had tread separations in about 7 years and very little tread wear.
    I've never heard that before. Sorry you had that. Did you always run them at max inflation?
    I hope my experience with the 2nd set is as good as the first.
    Always at max inflation. When the first tire on the utility trailer failed the tire shop guy inspected the other Maxxis tire and it appeared to be OK. So I used it as a spare. It was stored inside the trailer. Then about 1 year later I was checking tire pressures when I found this. Note the tire was stored inside the trailer.
  • Fresno Tundra Driver wrote:
    I’m right behind you with about 8.5 flawless years on my Maxxis 8008 tires. They are a great ST tire!
    Great!
  • I had a set of Maxxis M8008 on my 5th wheel and had tread separations in 5 years with very little wear on the tires.
  • I’m right behind you with about 8.5 flawless years on my Maxxis 8008 tires. They are a great ST tire!
