lawrosa
Jun 04, 2018Explorer
Buffblazer wrote:
Hi all, just picked up a 98-99 Lite Craft pop up truck camper. Had zero paperwork so I’m shooting in the dark here.
It has a magnetek 6600 series converter but I don’t know if it’s a 6606 or a 6612 since they are both listed on the panel and it’s a Option H.
Does this model have the ability to charge the battery? If not should I look into a converter/charger or just buy a battery tender and wire it in and just plug it into the outlet in the camper for when either I’m connected at home with shore power or using my generator out boondocking.
It’s a single 27 series deep cell it’s a beginner camper so not wanting to sink a lot of money into it, that is why I was leaning towards a tender but am open to a simple converter/charger also if it won’t break the bank.
Thank you. Also does this forum have a mobile friendly setup? Would love to post pics and such but primarily use my phone.
No charger on that one. There is a manual switch in there to run from converter or batterys. Code h means 15/15 duplex. I assume breakers..
http://d163axztg8am2h.cloudfront.net/static/doc/9f/dd/b0f57b6b26edd683f2694aabd639.pdf
I wouldn't use a tender, but a regular 10/2 amp charger at a minimum.
Here is a replacement 3 stage power center for 142 bucks..
http://www.bestconverter.com/Parallax-6730D-30-Amp-Power-Center-WDoor_p_325.html#.WxYzMEgvyUk
http://d163axztg8am2h.cloudfront.net/static/doc/e1/95/f09ff2026d89f5e61ea182fb9aad.pdf
http://d163axztg8am2h.cloudfront.net/static/doc/e5/03/193aed4b900dd5cb84a954b5ba4a/6700_series_owner_op_guide__rev_c.pdf
44,056 PostsLatest Activity: May 04, 2014
