kerrlakeRoo
Jun 05, 2018Explorer
With no charger built in you may want to look at a small solar setup for charging. Even a single 100 watt panel would go a long way if you convert the interior lights to LED's and ensure you dont have too many drains on it.
For using your generator look at the "Smart" chargers. When boondocking you would likely prefer a higher charge rate than 10 amps to cut down on run time, and you would be able to set it for maintenance when at home.
44,056 PostsLatest Activity: May 04, 2014
