donn0128
May 31, 2013Explorer II
Two of the lines should be low point drains and the third should be the potable water tank drain.
As for jack? I have a 10 ton hydraulic jack that i use. I also carry the correct socket for the lug nuts, a 4 inch 1/2 inch drive extension and breaker bar. Plus a torque wrench. In an emergency you can some times use the tow vehicles jack. Be sure to only jack under the spring perch.
