plasticmasterExplorerJan 22, 2018New power outlet questionI'd like to install a new power outlet to use primarily for my toaster oven. The only circuit that I can tie in to is the circuit that the water heater plugs in to. Are other outlets typically tied ...Show More
BurbManExplorer IIIJan 24, 2018I'm with you GMW, I have done similar. It's a case of adding convenience not capacity.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringNewbie power questionElectrical outlet issuesOutlet problem
