plasticmaster's avatar
Jan 22, 2018
New power outlet question
I'd like to install a new power outlet to use primarily for my toaster oven. The only circuit that I can tie in to is the circuit that the water heater plugs in to. Are other outlets typically tied into this circuit and would it be safe for me to tie into this circuit for another outlet? Would I be constantly tripping the breaker if toaster oven and water heater on electric were both on at same time?
  • Does the kitchen counter have no outlet in proximity? Seems odd.
    W/H is generally on a dedicated 20 amp circuit as they draw 12 amps. If the toaster is rated 6 amps or less you might get away with it.
    I recommend a load shed device to cut power to the W/H when using the toaster oven.
    http://www.bestconverter.com/Automatic-Load-Shed
    Pulling a new circuit would be best if you have access. Or unplug the W/H and just use propane.
  • When we want to use an electric skillet, electric griddle, or any of our electric space heaters, I run a separate electric cord from the shore power post into the camper. I have found that one electric space heater will work just fine through the camper's power system. But when plugging in a second, the breakers pop. Same happens when we use the electric griddle.
    Simplest solution, was to run a separate extension cord. For us, this was not a major issue, as I've always run a separate 50 foot cord from the campground power source to the picnic table so we can fix all our meals outside.
    For a while, I just put the cord through the window above the kitchen sink. Later, I realized I could shove it in the same hole the camper's main power cord comes out of, and then pull it inside the camper anywhere I wanted.
    So, in cooler weather, the cord is inside for the electric heaters, then back outside to fix meals on the picnic table, as we do not normally fix meals inside the camper, unless there's snow on the ground (that cold).
    You might consider just running another extension cord, you know, one of those orange ones you'd use in your garage. It's a bit easier than attempting to run new wiring or adding new plugs, that may still cause a larger AMP draw than your camper is able to handle (especially if yours is a 30 amp only camper.)
  • I'm guessing your water heater element draws about 1500 watts. That's 12.5 amps at 120 volts. What size breaker is it on? If it is a 20 amp breaker you have somewhere in the 4 additional amp range before you start tripping the breaker.(80% constant load will start to trip a breaker) What is the wattage of your toaster oven? I doubt your water heater and toaster oven will play well together.
  • I would expect/guess that the WH would have a dedicated circuit. Putting a toaster oven on that same circuit will likely result in an overload.
  • Not sure about other outlets, but a toaster oven and WH on at the same time would almost certainly trip the breaker. Simple solution is to set the WH on gas operation when you are using the toaster oven.
    I installed a 150w inverter with a transfer switch on one circuit that has outlets for both TVs and also includes the outlets by the bedstands, which is nice for charging cell phones overnight. Problem is that it also includes the outlet for the fridge...so I just set the fridge on gas mode when I'm running the inverter so the element is not powered, works fine.
    I usually run my WH on gas because of teh faster recovery time vs electric. After we've all showered, I shut it down for the day then power it back up in the evening for dishes.
  • Why not install new breaker? Many rigs have full size breakers which can be changed out to twin breakers that have two circuits in the same space.
