Terryallan
Aug 14, 2019Explorer II
mafitz wrote:
My first time posting but have been lurking and reading about campers for several months as I prepared for my new purchase. I have had two campers previously and had each 10 years and had little or no problems. Going into this I knew to expect some issues, but have run into more than I think I should.
Unfortunately we did not check this out as thorough as we should but would not have noticed any of the issues except for the hailed on air conditioner.
We purchased a 2020 Puma 31QBBH about two weeks ago. During the walk through they pointed out a piece of missing trim which was due to them taking the wall out and fixing one of the tank sensors. They said they had the piece on order. In addition, there was a tear on the corner of the dinette and they again said they had a piece on order. Seemed acceptable
We walked around the camper and checked everything out...... We bought the camper and took it directly to the camp ground.
While we were camping I did a more thorough look at the camper. I found the main AC had hail damage on the fins and quite a few. The other AC which they installed for me did not have damage so not sure why they did not see that. I rolled the awning out and noticed a wrinkle in the awning. After further inspection noticed there was a dent in the awning tube...
Ok.. Further inspection showed that the caulking on the slides where the front meets the side were about 1/4 inch separated. It appears that there was an adjustment to the slides at some point. I could see bare wood in the corner of the slide. Furthermore the seal at the top of the slide was offset by about six inches and therefore stuck out on one side of the slide. Again why was this?
We also found a chip in the corner of the counter top which we had not noticed.
After camping was over, I pulled the slides in and that is when I noticed the the corner of the dinette crushes into the corner of the counter top. Hence the torn corner of the dinette ripped and the chipped and hairline fracture of the counter top. How can this happen?
We had some other issues which were minor and what I would expect but adds to the overall frustration.
I contacted the dealer and they set up a time to come in. My problem is that we have to go camping labor day and are committed to that with out of state relatives. I asked if I could get my old camper while they worked on the new and he said they could not do that. So we agreed to set a date after Labor Day. I voiced my concern on the caulking issues and they told me to caulk the sides. I did that for the two sides I saw issues with.
This morning we had a heavy rain and I went out and checked on the camper. I found damp carpet in 3 of the 4 corners of the two slides. One of the sides I caulked did not leak.. Yeah!
So a long story and definitely not happy. Given the issues that I have I am not sure i want a patched up trailer. Is there any other recourse for me or give it to the dealer for awhile to patch it up?
Appreciate any responses.
Just hope you didn't get it at Camping World
