LeBout's avatar
LeBout
New RV toilet needed
Some good friends of ours who also have a TT realized that their toilet was no longer holding water in the bowl and now the toilet needs to be replaced. Anyone know of any good deals around? (They would love to get something a little taller than standard if possible.) Thanks in advance!
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    2oldman wrote:
    Thetford porcelain.
    These are so much better than plastic. Expensive, yep. Not a 'good deal', but a good toilet.
    I agree, we've got the same model, ie the China bowl in the tall model.
    But, like others have said, if you're up to it, you just might be able to fix your old one. Basically, the toilet never wears out, just the components like the seal, valve, etc, go bad and are easily replaced.
    If you want an upgrade though, go with the one in the posted link by 2oldman.
  • LeBout wrote:
    Some of you suggested repairing the broken seal. What would you suggest as a starting point for someone who has never attempted such a repair?
    YouTube
    That is a lot more difficult than it appears, which is why I recommended a new one.
  • Some of you suggested repairing the broken seal. What would you suggest as a starting point for someone who has never attempted such a repair?
    Going the cheaper route... Seal easy to replace if need be. Usually just something around seal letting water drain. For height, check out https://www.amazon.com/Thetford-24967-Toilet-Riser-White/dp/B0006H9364/ref=sr_1_2?ie=UTF8&qid=1501101166&sr=8-2&keywords=rv+toilet+seat+riser
    Works wonders on the knees.
  • Make and model would help.
    Quite often debris gets into the seal. It can be removed by cleaning. Thetford makes a tool called bent screwdriver. I made one out of a metal coat hanger. Cut it about a foot long, bente a 90 degree angle about one inch. Stuck the one inch into grove and cleaned the seal area.
    Replacement I would look at is a Thetford Bravura. Fits most bolt patterns.
  • Just repair the seal no need to replace the toilet. Seals can normally be replaced easily in a few minutes.
