Old-Biscuit
Aug 07, 2015Explorer III
Sounds like the PEX crimp tool was not used correctly by installer so I would be suspect of other fittings/crimps failing
Using a barbed fitting and hose clamp on PEX will also result in leaks...PEX is too stiff to be compressed around barb fitting by hose clamp to properly seal.
Go to hardware store
Get PEX cutter tool
Get some 1/2" PEX fittings.......Sharkbite (Home Depot)/Gatorbite (Lowes) work VERY well but are expensive
FlairIT fittings work well
Sea Tech (by Watts) are ones I prefer.
PEX has to be cut clean, straight, no burrs
Might need a length of PEX incase line is too short after cutting to get rid of crimps.
You can use a Dremel Tool with cut off wheel to cut across crimp......or fine tooth hacksaw. Just cut across crimp enough to weaken then use pliers to remove. Don't cut into PEX
Personally I just cut PEX into and redo the whole works vs trying to cut crimps off
Good luck
Get PEX cutter tool
Good luck
