mobeewan
Oct 13, 2014Explorer
I have one of these tankless water heaters that I use when tent and pop up camping. I was thinking about adding a couple screws on the side of the trailer to hook it on for temporary mounting and use for when I want lots of hot water. There are screw slots on the back of the tankless for wall mounting. The outside wall area I was thinking of was where the low point drains are located. I have already added quick connects for hose connections to the low point drains. Cold low point hooked to tankless inlet, tankless outlet hooked up to hot water low point. There is black gas pipe running on that side under the trailer too with a branch going to the kitchen oven. So adding a valve with propane quick connect there is no problem either.
If not enough hot water I might upgrade to This tankless.
