Grit dog wrote:
wanderingaimlessly wrote:
All of the laughter may be correctly spewed, but, the vehicle was new, the alignment should not be able to be questioned, and wearing out new radials in 22,000 miles is ridiculous.
YES, I would be screaming, My old Rams tires went 5 years and 70 k before I replaced them. And I would be trying to bring all the attention to the issue I could before I would just walk away from it.
Guess I'm just stubborn about accepting being screwed over.
Lot's of talk about alignment. First absolutely the alignment could be questioned and would likely be the predominant problem if the front only was wearing oddly.
The OP said "tires" not front tires, so guessing, perhaps incorrectly,that it is all 6 tires worn.
Eating front tires? I'd be at the dealer telling them to fix it. (Actually I'd probably just fix it myslef and save the hassle, but...)
Sure try a tire shop, see if you can get some goodwill there.
The tires on the driver side are wearing, both front and outside back one. The passenger side outside back tire is also wearing some, but not as much as the others. The alignment was checked and is within specs. This is apparently a TIRE problem, not alignment.
