blt2ski
Feb 21, 2017Moderator
Min lrC load rating, that would be a 6ply. 10Ply/LR E frankly would be way the heck more than you need. 10ply tires at 60 lbs vs an equal sized 8 ply at 60 lbs, do NOT handle a load any better, worst or otherwise, from my experience. Now if you want to disCUSS a load at 80 lbs vs the max 65 on a D rated tire, with a LOAD that is needed for the E rated tire.....now I will say there is a difference. Under like a typical 15 series truck is at, not worth the extra $$$$$$
WIth that in mind, Cooper and Toyo are at my top of the list, Michiblows the bottom, UNLESS you have the need for a 225-70-19.5, then the XDE M+S or new version there of in an LR G is a nice traction tire. Otherwise, not a fan.
Marty
Marty
44,056 PostsLatest Activity: May 04, 2014
