valhalla360 wrote:In contrast, lithium batteries can be drawn down to around 10% without harm and can charge fast right up to 100%. The result is you need 85-amp-hr of battery.
that is kinda misleading it, you are not hurting it by tanking it to 0%, and there is no reason to be afrade of doing so. the rated life span of a LiFePO4 is based on cycling from 100% to 0% many many times. I think the older batteries I was working with that had a 3500cycle life, if you cycled then twice a weekend for 33 year they would at that point only have 80% of the capacity left. ther new ones coming out are being listed as 8 to 10K cycle life. all staying above 10% does is give you a bit more cycle life than they are rated for, so ya it is good practice to stay above 10% but your not doing damage by going below.
