Acdii's avatar
Acdii
New to Camping, Questions have I
I am planning to take the family on a week long excursion to the Grand Canyon, and after looking at hotels, and such, the cost is extraordinary, add in gas, and meals, and its even more. So I started thinking about a TT Rental, guess what, cost is almost the same as hotels/motels, and that doesn't include the extra use in fuel or costs for camp sights. Plus .39 cents per mile after 100 free each day is the killer, rough estimate is $2600 just in miles.
So with that said, I started looking into used trailers and found what I believe would be the right model at a reasonable price, under $8K. Its a 2003 KZ 2405 slider. I will be pulling with a 2014 F150 Lariat EB. Plenty of truck to handle it considering its just a touch lighter than my 2000 Trail-Et New Yorker horse trailer, which is 3500# bone dry.
So for my questions, which I will probably have more as time goes on.
1. WDH.
I currently have a Husky with 1000# spring bars, but the tip ups are attached to the New Yorker, and not easy to remove. I don't know if I can get a second set of tip ups for it, unless they are pretty much universal, and it also does not have anti sway.
So do I get a second one with Sway control, and if so, cam or friction? I didn't need sway control for the horse trailer, it has such a low COG with the galvanized steel frame and heavy wood bed, with light aluminum body that it never swayed, but the TT are much higher off the ground, better to be safe than sorry, and I want to avoid the kind you have to disconnect in order to back up. Also are 1000# bars too much for that trailer, or just right? They are just a hair too much for the New Yorker when hooked to the F150, but worked perfectly when hooked to my original TV which was a 97 Explorer V8 AWD.
2. Power. I noticed these dont have generators. When I was a kid we had a Champion motor home, it had a generator, so you really could stop anywhere and have power. How is it done with the TT? Batteries, and how long do they last, what do they power?
3. Propane. I noticed they have small bottles, one has only 10 pounds of propane, the others 30 pounds. My gas grill has 20, so what does one of these use in the way of propane? Stove, refrigerator and furnace were all on the Champion, and it had a 40 or 50 gallon tank for propane.
4. Waste tanks. I noticed there are now 2 of them, grey and black. Assuming black is the pooper tank, and grey all else, when did they split them up? OH the memory of that fateful trip home when the waste tank was full and we couldn't find a dump station. We tried to hide it with pine air freshener. Now every time I smell pine air freshener it brings me back to that day.
Do both tanks drain out the same outlet, and where do you find dumping stations?
5. Camp Grounds. Not a clue! Never been to one, so no idea what is involved.
6. Waysides. When traveling and you stop for the night before reaching your destination, are there any places to avoid? We will be traveling the Interstates for the most part, so any layovers will be on the Interstate.
That's all I can think of at the moment, will probably have more as I get more into this.
For background, been a CDL carrier now since 1988 hauling flatbeds of lumber and steel, so these little trailers are nothing compared to 80K# behemoths I used to drive. The tractor I drove alone was longer than my old F350 Dually. Already speced out my hitch capability, with WD its 10,500# with a 1050# TW. Payload of the truck is 1470, which with just me and the topper leaves plenty of room for the TT, but with the wife and kids its at the limit, if not slightly over. I doubt this would be an issue, but wont know until I actually pull it, and will see if I need to add weight to the rear of the trailer to offset it a bit. The TT I am looking at when wet puts a lot of weight up front since the clean tank is in front of the axles. So do I run empty or partial will be the question. Will be travel with 2 kids and 2 more adults so there will be 5 of us, and the TT I am looking at is a bunk house style, which I feel will be perfect for us, small enough to not be a handful with the F150 yet large enough so we aren't at each others throats at the end of the trip.
  • Thanks for the replies. That link was perfect. oh and :thumbs: is an emoticon of a smiley giving a thumbs up.
    I have a 12x6 enclosed that I haul my RC planes with. I installed a power system using a 6W solar panel, deep cycle battery and an inverter. I found out the hard way NOT to use the solar panel by itself. It fried the battery. It then fried itself somehow as it wont put out more than 7 volts under a light(literally) load. I have LED lighting strips in the trailer, and last year when I first hooked it all up the panel would light everything, now only the red lights work. I replaced the panel with an 18W panel that also has a battery controller to prevent over and under charging, now just have to replace the battery, I tried to recover it, but its too far gone.
    Any traveling tips? Going to run from Rockford IL to the Grand Canyon, Bryce Canyon and back. Going south first then across OK, TX etc. Any places along that path that are good layover points? The trailer I am looking at has a rear slideout for the queen bed, so it has to be extended in order to use it, don't know if that will be an issue.
    Anyhow, the rest of the answers helped me relax a bit, thanks, appreciate it.
  • 1. The snap up brackets are pretty much universal. Try etrailer.com You can get a friction sway bar at the same place.
    2. The battery will last 3 or 4 days as long as you don't run the furnace. With the furnace on you might get 1 day if your lucky.
    3. Most TT's have 20 or 30 lbs tanks. One 20 lbs tank will last about of year of normal camping, again, minus furnace.
    4. Never found a campground yet that didn't have a dump station, provided it's not rustic camping. If it has electric it'll probably have a dump station.
    5. Find a campground with at least electric at the site and give it a whirl.
    6. As long as you are not putting out the slides and the BBQ (basically just stopping to sleep) no one will probably bother you.
  • RoyB's avatar
    RoyB
    Explorer II
    A great place to start out is your back yard then move up to a local Camp ground... You more or less have to learn on your own what you need to do...
    The camp grounds are all setup to handle all of your needs - most have a camp store...
    I always noticed where the local WALMART and LOWES stores was went finding a camp ground...
    Like driving your big truck - you will be an expert about 200 miles down the road... Some of us are RV CAMPERS and others are RV TRAVELERS and make the long haul trips.
    Roy Ken
  • 2oldman wrote:
    2. ***Link Removed***
    :B What? no :thumbs: EMO? LOL Thanks, it's basically what I built into my RC Plane trailer then. Only difference is I added an 18W solar panel to charge up the deep cycle battery. How many batteries do they typically have?
