afidel
Nov 29, 2017Explorer II
On the generator mount, did you tie it directly to the frame? Did you make sure your frame can support the kind of torque load a bouncing generator on a torque arm can generate? Also did you check your tongue weight with the generator on the back and other camping stuff loaded to make sure you're at at least 10% tongue weight.
The first couple questions are mostly about the safety of whomever is behind you if the generator decides to rip a chunk out of the frame (happens all the time with bikes and rear bumpers). The last question is about both your safety and everyone else on the road with you, having too little tongue weight has a severe negative impact on handling and can lead to dangerous sway.
44,029 PostsLatest Activity: Jan 19, 2025
