brought her home last night. 2008 23ft Flagstaff MicroLite MicroLite LB. very well maintained, family I bought it from are the original owners. dealer maintained (roof and seals and winterizing) every...
The first thing is to inspect the brakes, bearings and suspension. Knowing that it is roadworthy is more important than the pretty stuff. You mentioned bearing buddies, I hope not because they keep a constant pressure on the grease eventually pushing it into the brakes. More likely you simply have a grease fitting on the end of the axle, and that too can cause grease to be pushed past the inner seal. I suggest that you hand pack bearings and never use those gimmicks.
