GeorgeNJ
Jun 22, 2015Explorer
donrebyct wrote:
Thanks for the input. As for the hydraulic lifting system, I would think all hoses should be replaced on a 20 year old system. The owner already had to replace a hose on the pump that ruptured as they were preparing to take the camper out for the first time this year. My hose looks good, even for it's age. there is only one thin hose from the pump to the cylinder, it would be cheap enough to fabricate at an auto parts store like, Napa.
It's a pretty nice unit, and would work for us, especially if I replaced one or both pull out beds with folding walls. But, I can't see paying anywhere near $3900 for it. A quick NADA check for it came up with about $1800 east of the Mississippi; also stated higher west of Mississippi. But, I doubt it would be double. They must be dreaming or are looking for a sucker. I've found a useable old pups around here from 150 (needing some work, but not a wreck) to 450 for usable (old), most older in decent shape are around 900, come the end of the summer, early fall the prices will drop.
By the way, did you use plywood for the new walls and piano hinges? My thought was to use 1" Styrofoam with maybe a 1"x2" frame, and piano hinges. That would give me some insulation. I would also install a window from one of the RV salvagers in the area.
I used 1/4 plywood underlayment with FRP glued to it for the exterior & painted on the inside. I bought piano hinges to attach the little wing walls, but decided to use aluminum channel to make the connection to keep everything separate pieces, less awkward when setting up and breaking down. If/when I put back a bed end, I would make my walls just like the old Apache hard wall pup had (you can find a setup video on youtube). It would be easy enough to replicate with the 1/4" plywood & Frp panel, piano hinges & aluminum channel.
Post more pictures when you can.
44,068 PostsLatest Activity: Jun 01, 2026
