fieldtech03's avatar
fieldtech03
new to rv life.
I'm new to the whole rv life. I haven't bought one yet but I looked at a 97 Dutchman for $4700. Outside is in really good condition but the pilot won't light for the fridge. I'm just wondering if it's a fair price for the unit. Any feedback is appreciated.
  • Tires and batteries are no biggie. Yes, you need to have them, but every RV will need them at some point. Asking for a price break if they're due for replacement now is always good, but I wouldn't consider them a make or break deal.
    Fridge - will it work on electrical? If so, then it could be something as simple as a new thermo-coupler (about $12 and easy to replace). If not, then that's a big expense most likely.*
    Have it checked out for fuel leaks. Engine fuel (if a MH) and propane. These are usually easy fixes (replace hoses), but can be costly if the leak is in the tank or in the appliances. *A propane leak in the fridge could also be the issue there.
    Check stove/oven, run both hot and cold water and check for leaking.
    If MH, have engine, brakes, etc. all checked out. Even if told that the brakes were just replaced - get them checked (someone replaced the rear brakes in my clipper, but forgot to add brake fluid).
    Be prepared to put additional money into it. Maintenance will be needed regardless of what you buy; repairs or replacements could be needed at any time as things age. Make sure your budget will allow for those costs as needed.
  • Its my opinion that the price is certainly on the high side for a 17 or 18 year old RV (depending in exactly when it was purchased) where there is a problem with a major appliance. That would be somewhere around 25% of it's selling price new. Also keep in mind that Dutchman is not a premium model. At the VERY least let the owner fix the fridge to your satisfaction and you already know of some other items you'll need to R&R. Also remember it's STILL going to be the same age after everything works so future repairs are likely.
  • I thought about renting but just decided this week to got the rv route. I got transferred to San Antonio for work and the rent for apartments is ridiculous.
  • Yea it needs new tires and battery. No leaks that I could find. The body and inside are really clean and straight. Pilot on the water heater lights and stays lit. Overall is really nice
  • Have you considered renting an RV for a few weekends before dumping thousands into an RV that may or may not meet your camping preferences?
  • Probably, though in that price range, condition is everything. I have seen mid-90s RVs that looked new and have tons of upgrades, and some that I would be afraid to drive OR sleep in!
    Look for signs of leaks or body delamination.
    Engine or transmission replacement would likely be more than the $4700. Tires are expensive - check condition AND manufacturing date. Generator problems might mean a couple thousand.
    Many people replace the fridge with a residential type. Repair might be just a cleaning of the pilot.
    Most of the rest of the stuff, batteries, water heater, furnace, etc., are hundreds to replace and not thousands.
    Tell us more!
    Matt B
