cougar28
Aug 11, 2019Explorer
Water pressure regulator-so you don't over pressure you rv water lines while hooked up to city water.
Clear tubing-looks like a siphon line to winterize your water line.Pull rv antifreeze from 1 gal jug via the onboard water pump.
90deg elbow for city water hook up-keep the hose from kinking while hook to the RV.
Not sure about the grease.
Not sure what item you want to know about there.
Drinking fresh water hose. So you don't get that garden water hose taste.
Don't know on that one.
Sewer hose support.Holds the hoseup with a slight decline from RV to dump inlet.
