Community Alumni
Mar 22, 2022Not applicable
wanderingaimlessly wrote:
As a generalization, Winnies are usually considered superior to Forest River products. That said, either can be either good or bad on any individual unit.
Look at both carefully, look for fit of cabinetry, materials used, plywood vs particle board, hardwood vs plywood etc, then decide.
Generally freestanding furnishings are better than built in. Appliances will likely be comparable. Depending on how you intend to camp, tank sizes may become important.
If you are looking at new, you may want to compare warranties.
Happy hunting
What he said. I owned a Mini Lite for a couple of years and was not impressed with the materials and workmanship. In order to make then "Lite" they use thinner materials to cut down on weight. I weigh 200 lbs and the floor on my Mini Lite flexed (sunk) when I walked on it. Did I mention the vinyl flooring came unglued in the middle and I had a giant air bubble underneath it? Compare the dry weights if they're similar in size. Go with the heavier one.
