madMatador78's avatar
madMatador78
New to the Site and travel trailers
Hey all,
New to the site and to travel trailers, just upgraded from a 6 ft pop up to a 1978 Holiday Rambler Presidential 3000 trailer. 30 FT long.
I was a little overwhelmed at first, only because I've never had anything like this before. Roof Air works, Fridge works, and most of the plumbing seems to work (had one small leak in water valve for toilet) stove works.
Only thing I haven't gotten working yet is the furnace, I need to pull it out of the cabinet and clean it I think.
Have a 97 Ford F-250 Diesel to pull it with, I'm still trying to figure out the weight distribution hitch set up. It looks like I have some of the components on the trailer but need the stuff to go on the truck. I'll see if I can post a picture. Thers these 2 bars on the trailer, and they swing it looks like, and they have some chain on them and theres a place to hook the chain. Still have to get safety chains on the trailer, the previous owner had no clue what I was talking about when I asked him about them. Right.
Anything else I should be looking for? I sealed a couple of windows because they were leaking, over all everything seems solid, ran bleach through the water tank. I know I must sound like a total noob, hope to learn something here.
Thanks again!
  • madMatador78 wrote:
    Hey all,
    Thanks again!
    Welcome.
    The two bars are spring bars, they are what transfers some of the weight forward to your steering axle.
    I would go to a hitch store and take a look at their demo setups, it will give you an idea if you have the whole setup or are missing parts. If your missing any parts your probably better off buying a complete new setup.
    Once you have your hitch sorted, you will want to load your trailer as you would for a trip then find your nearest scale and weigh your rig. You will probably have to do some adjusting to you cargo and the weight distribution hitch to get the rig balanced. Once your done that make note of how you have your rig loaded for future trips.
