eluwak
Mar 22, 2015Explorer
We had a 2012 Pathfinder S V6 4x2, basically the lowest optioned model available (we only had floormats added). The payload rating was less than 1200 lbs. per the door sticker, and was verified by the CAT scale. This means that every other model package has less than we did. Before getting well versed in weights I had already pulled a Jayco 26BH 400 miles through TN mountains. The experience what white knuckle, and I'm sure I was wayyy overloaded. Before the trip I had installed airbags in the rear because if you put a bag of dog food in the back of a Path it will drag on the ground, So this pic has the airbags up to 35 PSI.
My advice is to either go with a pop-up or find a better TV if you want to have a TT. A Path might work, but it won't be the most pleasant experience in the world.
