fitznj
Oct 03, 2016Explorer
Q1. Do the batteries charge when plugged into an outlet?
yes - but make sure your master switch is ON:
Q3. Do you guys pull your batteries off and trickle charge at home when not in use? I will be storing my trailer locally so I'm wondering if I should pull the off?
Turn OFF the master switch before storage; I only remove the batteries for the winter
Q4. Is upgrading to 2 6-volt batteries worth the upgrade?
Not really; I use WalMart batteries for $80 each and replaced every 3 or 4 years
44,027 PostsLatest Activity: Mar 05, 2025
