Bumpyroad
Jul 19, 2013Explorer
Atlee wrote:
Don't think so.
For one thing, I don't use any water trying to get the hot and cold balanced enough to take a shower.
For the 2nd thing, I might use 2-2.5 gal total for the shower.
Doesn't take much water to wet down, turn off the water, soap down, then rinse off the sope.
Repeat process for the hair.Bumpyroad wrote:Atlee wrote:
With my hot water, I never heat it up all the way. I will cut the water heater on long enough to get the water just above my body temperature, then cut it off. That way, I just use the hot water side and don't have to worry about cooling it down with fresh water.
don't you end up using the same amount of water. 5 gal hot, 5 gal cold, vs 10 gal lukewarm?
bumpy
OK< make that 1 gal hot, one gallon cold vs 2 gallons of lukewarm.
bumpy :)
44,055 PostsLatest Activity: Dec 23, 2025
