pappaone wrote:
I traded the MH for a TT , it is a Surveyor 220 RBS. Has a hitch weight of 486 lbs, a GVWR 4329 and a CCC of 7486 lbs. Need to purchase a tow vehicle and have been looking at the Nissan Armada Platinum. Supposedly the Armada has a 9500 lb towing capacity, my question is what are the views of this combination?? will it be a good tow vehicle or do I look at something else. Thank you for any input a newbie can use.
Rich
Rich - Something is not adding up in your numbers. The CCC can't be more than the GVWR. I thing you're getting dry weight mixed up with GVWR. GVWR is the maximum the TT can weigh when fully loaded. Can you post new numbers?
