chris_gaitan
Aug 28, 2014Explorer
CaveRun wrote:chris gaitan wrote:
The fabric where it attaches to the trailer is the part that's damaged.
I'm not even sure I could roll it out without it coming apart. I'm assuming the rest is fine since its been rolled up.
That's what I thought. . . I'm sure the rest is OK too since its been rolled up!
I seen one like that before. The rest of the awning looked new.
You can put ''white Gorilla duct tape'' on it and get several more years out of the awning! . . The awnings are ''double layered'' and most of the time its just the ''top layer'' that is sun baked.
It shouldn't come apart if you rolled it out. . . If it does, You was planning to replace it anyway.
I'd try the white Gorilla duct tape. .Its weather-resistant, withstands moisture, UV rays and sticks very well! . . Also, you can't even notice it on the ''top'' of the awning when it rolled up or rolled out!
Wow that sounds like a great idea. I'm going to roll it all out and see if I can do it. It would be great to get a little use out of it before I have to replace it and it it doesn't work I was going to replace anyway. Thanks so much for the heads up
