nremtp143 wrote:
Also keep in mind that the gauges in all of our trucks are just IDIOT lights. Meaning by the time they move, something is really wrong. If you want to really know what is going on with the truck, buy a gauge like the Edge Insight CTS #83830 here Edge Monitor IT will show you exactly what the truck computer is seeing and takes out the "wonder if everything is ok" questions. You watch the info in real time. By the time most gauges show a change, damage to your truck has probably occurred. It will monitor several parameters at a time and you can check it at a glance. I love mine..This is NOT a programmer...a monitor only.
What he said... THe engine temp gauges on the GM trucks are known for being very innacurate. You can get accurate readings but don't need to spend the coin on an Edge Insight to do so. If you have an Android based SMART phone you can download the free Torque app and pick up an OBDII ELM bluetooth transmitter off of ebay for around ~$20 that plugs into the OBD port (below dash) and will give you accurate water temperature readings.
