TrentonTom wrote:
Battery is often dead on trailer due to lack of use and I will check the fuse for the "hot" wire. I am guessing that would be in the fuse block? I haven't really had a need to look for blown fuses yet. Thanks for all the info.
Tom,
Replace your battery and I think that all systems will work as they should.
If you can't keep the battery charged in the trailer during storage take the battery home with you and keep it on a float charger to maintain a full charge.
I would bet that you also have no power to your trailer brakes when you pull the break-away pin.
ArizAl
