SoundGuy
Apr 17, 2018Explorer
canuckystan wrote:
I'll be picking up a new Rockwood Geo Pro 16BH in May. Dealer said I should try without a WDH. Also said solar panels can keep batteries topped up.
Trailer is 3000 pounds dry. Towing with 2014 F150 with tow package to 13,000 pounds. Thoughts on WDH?
Also, do you think I should invest in an 800w Generac generator? How long would that take to re-charge 2 6 volt batteries? No TV, no air con, no intention to run anything off a generator, strictly using batteries for basics like water pump, furnace fan, maxxair fan, etc.
Unfortunately you haven't provided anywhere near enough specific information about your new Rockwood Geo Pro 16BH nor your F150 for anyone to say for sure what your best answers are but based on experience I'll give it this go ...
With a brochure listed dry weight of 2874 lbs chances are this trailer's actual sticker weight as it arrived at the dealer could be 3000 lbs, to which you would then have to account for the weight of those two 6 volt GC-2 batteries you want to add plus the weight of any water you may travel with. With a CCC of just 1046 lbs, some of which will be lost to these aforementioned items, your actual remaining CCC will be much less, which in turn means that chances are this trailer's GVW loaded & ready to camp could easily reach it's maximum GVWR of 3900 lbs. That in turn means that it's gross tongue weight at a minimum 13% could easily exceed 500 lbs which is likely the maximum load you should put on your F150's hitch without the benefit of WD. That being the case I'd personally recommend you do invest in a properly sized and adjusted WD system. With this size of trailer and considering your F150's decent wheelbase I'd probably not bother with a separate friction sway bar, just as I don't with my own setup pulling a 4800 lb trailer with my Silverado, using just a trunnion bar Reese WD, no sway control.
JMO but if you're considering a genset like this 800 watt Generac I'd suggest you instead invest in 2000 watt Champion inverter genset that will easily handle the tasks you have in mind. It's often on sale at Canadian Tire and you'll find that factory parts and support are far more readily available than for Generac.
Solar? Nothing wrong with the idea BUT if you plan to camp on well shaded sites as many of us here in Canada do it won't do you much good. Unfortunately you haven't indicated where in Canada you are or where you intend to camp but I wouldn't underestimate the impact of camping in shade will have on any plans you may have for solar, not to mention that solar just isn't as effective this far north as it would be in much more southern, desert areas of the US.
Congrats on your new trailer. :B
44,059 PostsLatest Activity: Mar 18, 2026
