mark1228
Jul 07, 2014Explorer
This is not directed at the OP, but when a water tank falls out it CAN be possible that it is the owners fault. If you overfill the tank with a high volume hose water cannot escape out the vent line as fast as you are filling it once the tank is full. When this happens, the plastic tank will change shape and can bend or break the supports holding the bottom of the tank. Most water tanks are supported by the frame but when the tank changes shape, it can fall from those frame supports. A friend of mine did this a few years ago and the water pressure actually forced his floor up and it ended up as a total through his insurance company. Just sayin, be careful when filling your fresh water tank...
