Fishbreath's avatar
Fishbreath
Explorer II
Nov 05, 2021
New Truck, 2013 Northstar Pop Up
Wondering Why......
I had a 2013 GMC 3500 SRW Long Bed which I used to carry a 2015 Northstar Popup camper. When using the camper, I would always remove the tailgate before installing the camper. The camper has a PVC tube running across the back for the sewage hose that hangs a little lower than the camper and there are hot/cold water drains on the right rear that also hang a little lower than the camper bottom. I believe these were the reasons that i was told to remove the tailgate. These stick out a few inches from the truck bed and are above the tailgate.
Yesterday, I was offered more for my 2019 truck than I paid for it three years ago ($6K). I purchased a 2022 GMC 3500 gas SRW. It came with the Pro Grade tailgate. This is not something that I needed or wanted, but it was part of the package.
As I advance in age, removing/installing the tailgate is becoming more difficult as it is unwieldy and heavy. There are also wires attached to the tailgate that operate the lock and camera.
So here is the big question. If I remove the hose carrier (I never use it) and recess the hot/cold line drains, is there any reason that I can't leave the tailgate on the truck while using the camper?
I believe that I could attach the Brophy steps to the Pro Grade tailgate with little fanfare, creating a little landing outside of the camper.
Please let me know if you have any suggestions or ideas.
Thanks.
Bill
