marpel wrote:
So, my choices are:
GMC Sierra 1500 6.2L 3.73 420/460 DFM (don't want DFM) 26gal. One of the more pricier choices.
GMC Sierra 2500HD 6.6L 3.73 401/464 36 gal. Middle of the road in price.
Ram 2500HD 6.4L 3.73 410/429 31 gal. Weird thing is, the model is Big Horn, but can't seem to get Big Horn package with crew cab and 6 1/5 ft bed. So, one of the more pricey, comparable to the Sierra 1500.
Ford 2500HD 7.3L 3.55 430/475 36 gal. Cheapest (by about 4K pre-tax).
All are about the same size, within an inch or so in every dimension, and within a couple hundred pounds in payload and towing - with Ford leading the pack but not by much. The 1500 is smaller by a bit, quite far behind by at least a thousand in payload and 2500 in tow, and does not have an HD engine, of course.
Although we will be looking at getting a bigger trailer, I doubt we will get even close to 3500 territory, which is why I listed the 2500s.
Regarding mpg, while I, like everybody, would like to get super decent mileage, a decent ride and tow is priority.
Thanks to everyone, I have been learning a lot.....but still can't figure out why the smallest(L) engine has more hp/torque than the bigger HDs. Go figure.
Marv
Understand that ANY 3/4 ton will have far more useable payload than any 1/2 ton, contrary to the "ratings". And most srw 1 tons only have more payload due to heavier rear springs, ret of the chassis is the same as a 3/4 ton, except in the very upper end where some 3/4 tons have a slightly smaller rear axle (like 9000lbs vs 10000 or similar).
Not that a 1/2 ton is incapable, but in broad strokes, 1/2 ton is a completley differnt truck than the HDs and 3/4 and 1 ton are very similar.
