SoundGuy
Jul 30, 2018Explorer
Farmerkev wrote:
Why are you putting your tongue jack blocks in the wrong way?
Should be long ways with slope, not short.
Nope - we've been through this before. :R Look carefully at how I chock the trailer and you'll see it can't go anywhere as forward pressure exerted by the rear set of tires pushes against the rear set of rubber chocks which in turn pushes against the hardwood spacers which in turn pushes against the front set of chocks which in turn pushes against the two front tires. Those wheels are bolted to the wheel hubs which are part of the axle assembly which is bolted to the equalizers which are bolted to the trailer frame. Regardless of slope there is no lateral pressure of any kind on the tongue jack or the stack below it, therefore I can place the stack any way I want to. How 'bout that. ;)
44,068 PostsLatest Activity: Jun 01, 2026
