- geekyguruExplorer
gmw photos wrote:
its a schwintek. Can u post vids?geekyguru wrote:
SGardiner wrote:
Did you ever get the slide issue resolved?
yes. apparently there was a wire that had come undone on one of the motors. I wish I knew how to access that motor should it ever happen again
Is it a Schwintek slide ? If so there are some videos on how to deal with problems with them. They are simple to get to and disengage if need be. - gmw_photosExplorer
Is it a Schwintek slide ? If so there are some videos on how to deal with problems with them. They are simple to get to and disengage if need be. - Doug33Explorer
I'm glad to hear that it was a simple fix, and hope you are now enjoying your Bullet. I know I am! - Ridgerunner29ExplorerWhen I had a TT with a slide, I had to have the trailer level and no pressure on the stabilizer jacks when extended or retracting the slide.
- geekyguruExplorer
yes. apparently there was a wire that had come undone on one of the motors. I wish I knew how to access that motor should it ever happen again - SGardinerExplorerDid you ever get the slide issue resolved?
- Doug33ExplorerI have the same exact TT and love it! I have not had any issues with the slide. Did the dealer demonstrate it when doing the PDI? I asked the tech how I crank the slide in if the mechanism fails. Apparently you have to unbolt part of the underbelly to get to the crank location. So I hope the slide never gets stuck! I've used the slide dozens of times with no issue so far.
- mhardinExplorerHave you checked the top of the slide for a slide lock?
- geekyguruExplorer
#40Fan wrote:
Only one motor on that slide.
really? So it must have come off of track or an obstruction? - _40FanExplorerOnly one motor on that slide.
44,027 PostsLatest Activity: Mar 05, 2025
