FishOnOne
Mar 11, 2015Nomad
Turtle n Peeps wrote:
If it bothers you why not change it? Just spend the 50 bucks and then you will be happy.
I'll tell you right now you would be dumping out good oil. If you think I'm wrong get a Blackstone kit and have the oil you dump annalyzed.
As far as swarf goes, that's what the filter is for.
A Blackstone analysis will tell you on the factory oil is your aluminum and iron will all be high and above universal averages, hence the reason to dump the oil and replenish with a new load.
