- Colo_NativeExplorerI am going the put one in on my TT BUT Lippert came up with a new design no screws, it is a press fit and takes 16 plastic release tools to remove and I was quoted $52 with Shipping. Heres the link.
https://www.lci1.com/assets/content/support/technical-information-sheets/Doors/TI___279_RV_Entry_Door_Pressed_Window_Replacement.pdf - ScottGNomad
Does that one have the built in blind like the OP's product does?
I installed the same product as the OP because I wanted to have glass I could see through and also have a nice blind. It's a surprisingly well made unit.
The sealant is pre-applied and with an electric drill it only takes about 15 minutes to install. The part that takes the longest is removing the old putty. - mountainkowboyExplorerNice, might have to look into that for the S&S
- stevenalNomad IIWith outward opening screen doors, you'll need to open the door prior to raising the blind. No quick view out the back with this.
- RV_daytraderExplorerI put in a clear door window and put a shade on the screen door to block off window at night.
- maxum1989Explorer II
I did the same as this in my Northern Lite. I can now raise the blind to see out the clear glass without the need to open the door first. - BedlamModeratorSame as my Host with the internal roller blind.
- Travels_with_YoExplorerMe too. Bought a piece of clear tempered glass for $22 and had it filmed at 18% for another $20. Then a $12 roller blind from Ikea so $54 total investment :-)
- jaycocreekExplorer IIFirst and foremost,I like you mod..They should put those on all RV's.
Having lived in RV's for years, I can say that the biggest weather leak for cold or hot air is the door,so I prefer the full shade(top to floor) over the door.While it is weak,it helps... - Camper_Jeff___KNomad IIII'll have to get one too.
44,029 PostsLatest Activity: Jan 13, 2025
