wiredgeorge wrote:
If the trailer comes with a jack (it has four leveling jacks on the corners), do I jack up one side, take them in, then the other? I do have jackstands but placing them under an axle and having them support the trailer weight makes me uneasy. Dry weight is 3820 lbs and the jack stands are rated 2K lbs I think (bought them for my trike to raise the rear and hold it for service). Is there a clever way to remove all four tires/rims for replacement at a tire place?
I wouldn't set the trailer weight down on those tiny little stabilizer jacks. Your trailer has a tongue jack that should be holding 10% of the trailer weight (about 400lbs) that leaves 3400 for the trailer axels. How about buying two more jack stands and putting one on each end of each axle? That would only be 850 lbs each jack stand, assuming your trailer is balanced.
