totaldla
Feb 06, 2017Explorer
horton333 wrote:Hmmmm, so if I cranked the WD hitch up till the rear wheels on the tow vehicle are off the ground, where did the tongue weight go?
Typically a trailer axle to rear wheels is going to be longer than front wheels to rear eheels, so reflected weight is less than half the weight transfered to the front wheels which is where my flyer of a 100 pounds is coming from. Sure could be 200 or even more sure, a very short but very heavy front trailer it could be 300.
That would be truly ironic if someone thought more was always better to the point of taking too much weight off the rear wheels with weight distribution, and ending up with worse stability.
