Tequila
Nov 23, 2015Explorer
One solution for both is to get a small FM modulator that powers of the USB port on the TV. This is the one I use:
Search for "Car Kit LCD 3.5mm Handsfree FM Transmitter Modulator USB for iPhone Android" on E-Bay
Then get a small FM receiver with earphones. This one is excellent
Search for "Sangean DT 180" on amazon (or DT-120 which is white
This forum would not let me copy & paste the links.
Set the modulator for 87.5 or 87.7 which your DVD receiver can likely receive but is not used for outside staions. You can play the TV sound through the DVD player that way or use an A/V cable as somebody else suggested. You may have to use somem splitters and adapters at the TV end to get the output sound into the FM Modulator and/or an A/V cable. Your wife can listen to the TV or a DVD using the portable FM receiver.
Works for me.
Works for me.
