yankeeslover's avatar
yankeeslover
newbie questions on black water tank and campgrounds
2011 jayco featherlite. I was reading the owners manual for the 2013 model as I have not picked up my camper yet. im real new and dumb so far with all these terms. I understand that the black water holding tank is from the toilet. heres my question, the book says that when hooked up to hookups at campground that I keep the holding tank release closed until its 3/4 full and then release it.. im confused.. how does the black water hookup work? I understand if im at a site without hookups then all the toilet stuff goes into the holding tank and when I leave, or when its full then I drive to the dumping station and hook it up to dump it.. .but im confused on when im using full hookups. when im using hookups does that mean I bypass the holding tank? or does the toilet still flush into the holding tank and then from the holding tank out to the sewer system? and if this is the case why does book say to keep it closed till 3/4 then open it? if that's the case it seems like even during full hookup site I still have to fill up holding tank then release it? I was under the impression that the point of a full hookup site was that so when I flush the toilet it leaves the camper right then and there and doesn't go to holding tank... im confused..LOL
  • so, at a full hookup site, I let the holding tank fill up, and then I just dump it? and then let it fill up again? im going memorial day weekend for 3 nights.. they want $9.00 more per night for a black water hookup.. probably better off just saving the cash and just dumping before I leave. there are bathrooms right next to the campsite that im in..clean ones. now, also, gray water, does that get dumped into black water too, or do campgrounds have gray water dumpstations also? thank you
  • To avoid issues of the dreaded pyrimid in your tank, yes keep the black tank valve closed until 3/4 full. What this does is allow the paper to partially desolve and keeps the tp from forming a pyrimid at the entrance of the drop from the toilet. You do not want that to happen. Dont ask me how I know.
    Keeping the valve closed allows all that is flushed to float and not harden. Then you can dump it at 3/4 full and it will drain without issues.
  • If you keep the tank open all the time,******will build up in the drain line. Letting the tank fill a bit first, puts some good volume into the line to keep it clean.
